Corksport Downpipe and Mid-Pipe Installed!
If I get the corksport mid pipe with the CPE downpipe and run it with my stock exhaust, will this match up? Would I need to alter anything?
that's correct. It's still the pricest as you've noticed. But, single DP piece is nice (less chance of leaks) and you have a catted option 'from the factory'
I got a high flow cat welded into the mid pipe....I just liked the corksport sound and wanted to get their full TBE. Plus it was cheap and that's important to a college kid lol
Will the CPE dp work with my stock catback or do I have to get a 3 inch cpe or other aftermarket catback?
mine did but it went after after like 10 miles. I've had thousands of miles on it now and nothing other than that. runs great
So aaron what did you have to remove to get to the bolts for the Dp?Im guessing the IC,Heat sheilds and thats it?Im going to be installing my TXS Dp in a week or so but I dont have any instructions.It looks very tight up in there and Im not looking forward to do this to be honest..I know my O2 sensors are going to be a pita since I know they are both stuck in there.
Thanks
You has email. I sent you a copy of the corksport instructions...they are really good. I'd use PB Blaster though, instead of WD40. Use lots of it on the O2 sensor and downpipe bolts or any bolts you are having problems getting that are really tight
My emisions place only connects to the OBDII port and checks for codes..Since the AP clears codes I should be ok during a check with no Cats.I may just put the stock midpipe back on with the cat just to keep the smell away tho.
