Control Arm Help!
2002 Mazda Protege Dx (BLOWN) 2002 Mazda Protege Lx
When trying to install new control arms on my 02 protege i noticed the threads of my subframe were stripped(toilet) and tried a helicoil and all that goodness, but I have come to a point where I must replace my subframe. Does the Manual and Automatic 02 protege have the same subframe?? If so can I just swap the subframe from my blown automatic one and put it into my manual daily driver. I have already swapped in a new tranny(yippy) so doing this job won't be too hard for me, but if anyone has done it before advice would be highly appreciated! Having trouble getting the 17mm nut off the super long bolt on either side of the frame... Also since i'm going to completely swap out the subframe what other upgrades should i knock out while im here? what's a great aftermarket steering wrack, etc.? View attachment 214224
The sub frames are the same. You could upgrade your sway bar while you have it out, or at least replace the bushings. Rear motor mount too. Not really any options as far as steering racks though, unless you can find an mp3 rack (I think they're different), or want to depower your current one.
