- 2016.5 CX-5 GT AWD w/ Tech Package
NEED HELP QUICK! Considering Used 2016 CX-5 Purchase: Update: Not Buying Stand Down.
I may be buying a car tomorrow, and I have a few final questions after an extensive inspection of the car today. If people can respond tonight, that would be great.
The car I'm looking at is a 2016 (not a .5 model) FWD Touring listed at $19,550 with 40,500 miles on the odometer and is listed as a "Mazada Certified Pre-Owned Car". No Bose or Tech packages. The car is a former rental, and appears to be in fine working order (post inspection), the Carfax is clean. Noted issues....
1) We started the car with the key outside of the car. The car through warning lights....red flashing brake light, yellow brake light, maintenance light, and one other having to do with the brake but I can't remember and the parking brake would not disengage (even though the key was now inside the car after starting it). We restarted the car with the key inside, and the brake warning lights went away. Is this a feature of the car to keep it from getting stolen, not disengaging the parking brake if the key is outside of the car?
2) The maintenance light remained on during the drive. The salesman said it probably wasn't reset after they did an oil change and would reset it. At 40,000 miles, are there other maintenance issues that would through the light on. It wasn't flashing, just the orange wrench symbol.
3) There was a weird stain near a panic bar in the back on the headliner. Does anyone know of a good way to clean the headliner? Does it soil easily?
4) In the spare wheel area one tool appeared to be missing. The slot for it was in the upper right side and looked like it fit the silver tool in this photo on the right above the yellow thing https://cck-dl.s3.amazonaws.com/2013 Mazda CX-5 Sport 2.0L 4 Cyl./Tire Change - Part 2.png. What is this tool for? Is it supposed to be with this trim model? EDIT" Looks like it's the TieDown Eyelet.
5) The drivers seat clicked back and forth just a little bit, a fraction of an inch, when accelerating or hitting the brake. Does anyone else experience this? Can it be fixed? Both the bottom cushion and upper back seemed to do it, maybe moved 1/8 or less of an inch, but it was noticeable.
6) All of the tires except the spare were Kumo tires, so I know they've been replaced. I'm sure they aren't the best tires, but I'm not familiar with the brand, are they terrible, or just not great?
Any help would be great, thank you!
