Cold start problem
P4PYT
mazda3
HI
I have few problems with my mazda3 1,6 petrol 2004, on cold start not always main lights flash for 1/10 sec, and on cold start is always struggling like on very week battery i checked battery is fine.. millage is 65k and
I found in manual my mazda need valve adjusting on 60 k if noisy.e .. what it mean noisy on cold or noisy all the time?
I have this car fot 3 years and never had a problem with it..
please help
P4PYT
Check your battery cables, especially the ground cable for loose or corroded connections. How do you know that the battery is good? Has it been subjected to a load test?
Hi
I have checked battery after two days stood in cold and was holding 12,54 volts i started up car several times after 1-2 sec running and replace battery from my other diesel car, stronger battery.
I was thinking about starter motor, ones i tried by mystieke Start the engine during operation and was a nasty noise of starter motor...
Anybody was adjusting valves already?...how much it cost,? is it big job ?
A load test is the best way to determine if a battery is good. Simply measuring voltage can be deceiving. I know that many Hondas, especially the older ones HAD to have their valves adjusted. I would at least have them checked within 10,000 miles of the recommended mileage if they are not noisy, now.
