I hold over 17 psi in second gear with the ap, so I am guessing the boost limit has been removed in 2nd. I only hit 12 psi in first though. A boost controller and map clamp might do the trick or cpe's standback
I don't quite understand the last part... bare with me I am a bit "turbo-dumb" I have really only worked with N/A V8 cars and have a little nitrous knowledge. This is my first turbo car.
*This is my understanding, someone correct me if I'm wrong.
With a map clamp you will be able to limit how much voltage the map sensor sees. So you "trick" your ecu into thinking your running say 16 psi when you have your boost controller set to say 20 psi. The map clamp will allow your car to run off the 16 psi fuel/timing tables, but for the 20 psi you dialed in.
yes map clamps can make you run lean and prevent your ecu from implementing safety measures like boost cut that prevent your engine from blowing. In my opinion the ap is far superior because it reprograms the ecu instead of tricking it. My point was if all you care about is full boost in 1st and second there are other methods to get it. I don't see why you would want full boost in 1st though it is useless unless you are running slicks. Cobb may release maps without boost limits in first in the future but I'm not sure about that.
Oh ok... I really don't think I want full boost right now but more boost then what the stock management allows with out risking a bad lean condition. I'm not upset with your suggestion I really don't understand the ECU tuning side and all of my options. The more some of the items are explained the more I understand and can ask better questions. I can see where I wouldn't want to remove all of the boost control from 1st because it could be pretty spin happy. Like I said before I am really not educated about this and I am hoping to learn from what ever you have to offer.
