Clutch Recplacement advice
mspk2
03.5 MSP
as the title states, im looking for some advice on swapping out my clutch. I will be doing this in the next coming weeks. first off im no noob to turning a wrench, just did a custom fmic to my baby, brakes on all 4 corners, solid su mounts. so is there anything that is going to make this a pain in the a$$? will I be losing fluid when I pull the axles? anyone have a write up on this?
get a friend. it will make life much easier. and yes you will loose fluid when pulling the axles. make sure you get a clutch that will hold your power goals. you don't want to make it a habit pulling the transmission. its really no fun.
