check engine light
dave7512
cel is on and the code says lean fuel to engine, also the car chokes when i step on it and it stalls whenever i take it out of gear
what could it be?
i already changed the spark plugs and oxygen sensor and that didnt fix it
what if you can blow hard on the wga and i mean hard, and it slowly leaks off?
As long as it dosent leak at six ponds or less it should be fine. Average human lung generated preasure is something like 10-16PSI so a slow leak at your maximum preasure is *probably* ok.
If the WGA leaks at six pounds or less it cant open the wastegate when it should and it needs to be replaced.
did you buy a OEM o2 sensor or the universal one? The reason I ask is about two weeks ago I made the mistake and used a universal one and I kept getting the same code. I ordered the OEM from montgomery mazda for 119.00 shiped no more CEL for me. Just my 2 cents
but if your wastegate is leaking doesnt that mean your not running full psi?
well, it could give you the problem of not letting you build boost... it could also give you the problem of higher boost spikes, or it could be unaffected at positive boost pressure but leak in vacuum, causing a major vacuum leak.
I've had both the last 2 happen to me. To the OP, do you have a boost gauge on your car?? If you do what are your vacuum and boost readings?? Try blowing into the WGA line to see if it will hold the pressure, but also try either hooking it to a vacuum pump or sucking back through it.... it took me a while to figure out that my ATP replacement wga had gone bad because it held fine when i blew into it, but didn't hold ANY vacuum at all once i finally tried hooking a vacuum pump up.
i just replaced my 02 and put a forge WGA in and i cleared the code, it hasnt come back yet but my A/F is reading wayyyyy lean under boost
