Check engine light, TPMS light flashing and power loss (2016 CX-5)
So I know this topic and discussion has come up in the past, but my 2016 CX-5, now at 200k, threw out the check engine light and TPMS light and I began to lose engine power. I could not go over 20mph and was close to stalling out. About a year ago, I changed out the coil packs and spark plugs due to the same issues [which I had a scanner that read for misfires]. I have not scanned the codes yet to see the problem. I was wondering what other solutions owners have come up with for this issue.
To: OP
The next thread seems to discuss a similar issue.
MAF: mass air flow sensor was the root cause for that case.
Update: Ran a diagnostic test and it read a misfire from cylinder 1. I checked it and found a bit of oil seeping through from the spark plug. the spark plug did have oil on it as well.
