check engine light is on~
Undercover
WHITE WRX
my p5 check engine light is on....but the engine is fine i seem so far.....um....dont know wt happen...oh btw, i just travel to LA then back to vegas on one day(almost 80-100mph all the way)....is that make the check engine light on? if yes wt can i do??
luis_alfonsosa said:
go to autozone to check the scanner, maybe is the O2 sensor or the catalyzer.
That's not to mention they'll pull the codes for free.
Check to be sure your gas cap is tight while you're at it.
i went to Autozone today and they give me the code P0442 and they said is the oil cap problem and something else but i forgot what he said....mostly is the oil cap problem if something else, what can it be? if really oil cap problem should i just go and buy another one and replace it?
They were wrong:
P0442 - Evaporative Emission Control System Leak Detected
Make sure that your gascap is on tight (turn it until it clicks) and reset the ECU. Also, don't fill the tank with the car running. If you get the CEL again, then come back here and someone who knows more than me will help you out.
To reset your ecu, disconnect the neg battery terminal and step on the brake pedal for something like five seconds to drain the residual charge. Then hook the battery back up.
god damn ! the CEL is keep turning on couple times, and i reset the ECU couple times but its still on !!!!!! and i didnt check wt kind of code this time.... but i'll check it tomorrow....i think is the same code (p0440)......oh btw i just installed the INJEN CAI after the first CEL came on....so is the injen cai made a other problem? anyway i just check the code tomorrow and i'll post here to ask u guys~~
Pretzellogic said:
They were wrong:
This forum is great, I love how soo many people actually are knowledgeable!
I am curious if I could find a list of all the codes and what they mean for whenever I have any CEL problems.
For for the thread jacking.
lol, who would ever do this? Also, refrain from smoking, or setting off fire works while fueling your gas tank.
ok....is a same code....P0442~ i'm not sure where is leak but im sure the oil cap is tight, maybe the oil cap have a small leak....maybe....but not sure....so how can i find out where is leak ??
Quoted from here:
Causes
A code P0442 most likely means one or more of the following has happened:
  • A loose or improperly affixed gas cap
  • A non-conforming gas cap (i.e. not factory/original brand)
  • A small leak/hole in a fuel vapor hose/tube
  • Other small leak in EVAP system
  • Faulty vent o-ring seal
Possible Solutions
With a P0442, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, or
  • Inspect the EVAP system for cuts/holes in tubes/hoses
Pretzellogic said:
They were wrong:
this happened to my wifes car, basically yea clear it and u should be good to go, its no big deal. hers happened 6 months ago we cleared it and its been running fine
