http://cgi.ebay.com/ebaymotors/_Car...adiZ2865QQcmdZViewItem?hash=item180251884193&
Has anyone ever used these? I'm skeptical about off brands.
raserx- did you buy it or install it. I would like to know how these shifters are.
I put in the cheap ebay shifter, similar to the OP's link, tonight. Did anybody else who has done this find that the snap ring could not be refitted? The aluminum shifter housing on the new part sticks out above the top of the black shifter base. The thing stays put reasonably well, but pulling up on the shifter would make the housing come out. It doesn't seem right, really. I may try to secure it with wire- not sure if there is much to wire to, though.
I drove it as is. It's nice to have shorter throws, but it's a little heavy/notchy now, of course...
which one did you buy exactly? link?
the lip was too largeon mine. It was the same size as the diameter of the tube it goes down into. The o-rings are still there to keep water out as is the rubber boot at the bottom. Just be sure to double check that the boot is installed correctly so that it mates up and keeps water out. I'll probably reinstall sometime in the future as I had the little metal ring in there upside down so the boot doesn't seal perfectly. There's hardly ever rin here so no worries.
