center point
Centerpoint does not function with all input sources.
And unless Bose re-worked the Centerpoint feature since my 2013 MY, you want the feature turned off at all times.
Centerpoint is a simulated surround sound option on the Bose equipped audio systems.
In the 2016 it works but it's basically a useless function. I keep it off.
I kind of like it, depending on the source. The higher fidelity the source, the better it sounds.
