Center Console Help!
jaytee05
Protege 2002
I have 2 questions regarding my center console.
My center console is stock and does not have the tape mount there is just a blank panel there.
1) Is there anyway I can wire an AUX using the tape button?
2) While I was opening and working with the center console, it seems something has happened and my heat stopped working does any know what the issue may be?
The car I am driving is the Mazda Protege 2002 ES 2.0
There is an auxmod board that plugs into the bottom of the unit that has the aux input on it. Sylfex.
http://www.sylfex.com/products/AuxMod/
As far as the heat not working, you probably didn't get the control rods back on the right way. There is most likely slack where you move knob but doesn't move the cable to change temp or air flow.
