P0101 - Mass Air Flow performance problem
P0171B - Bank system too lean
The check engine light came on and both codes came up. Basically after the engine warms the idle will start bouncing up and down from 750 to 250. Give it a little gas for a second and it stops for a minute or so, then starts doing it again. The behavior is basically identical to pulling out the MAF plug. Tried another MAF unit and the problem persists. Thoughts?
Car is a 2001 ES 2.0.
