i recently did an internal kit from ptp, while following the break in procedure i had some issues best described as fuel cut after about 1&1/2 minutes, where the rpms would drop down, then it would be fine this was when i was at 3500 rpm portion, not at 2500 or 1500 is that normal, or should i disassemble and reinstall?
