Sorry guys that I have been so hard to get a hold of- I was taking finals. The intake is designed to be used with the stock longer bpv hose, because I know that the vacuum source line isnt long enough to use the short hose. I didnt mean for my pics to be the ones that the installs are based off of, because I broke my bpv before.
The long rubber hose is supposed to bend 180 degrees from the BPV outlet to connect to the nipple. Its supposed to kink a little bit, but it isnt supposed to restrict airflow at all. There are two possible reasons for this- 1. I installed the BPV recirc nipple too low (or high) on the SRI. This is entirely possible because each nipple is placed by hand, and I could have made a mistake. 2. The hose I sent is for some reason not as high of a quality as it is supposed to be, causing it to either not bend enough or kink too easily.
I think the best thing to do is for me to send you another SRI, with my actual BPV hose (don't worry, it will work with the longer hose on the stock IC pipe). PM me with your adress again, since I don't have your mazda forums name tied with your adress.
If it turns out that the nipple is in the wrong location, then I will also send a corrected SRI to the others who purchased an SRI at the same time, since I usually make them in batches.
The last thing I want is for anybody to be unhappy. I understand that I am still new in this business, and hope that you guys will work with me and accept my sincerest apologies while I work out the bugs. I just want everybody to have cool intakes/pipes!
Slug420 - I notice now that your description mentions that you're from connecticut- I was thinking of going there to visit my brother in a week, maybe I could come and bring you a new SRI and help with the install?
