- Protege5 2003
The P5 my daughter now drives smokes like crazy - sometimes. This is the formula for a
smokey start:
1. start the car when it is cold.
2. drive it, but not long enough for it to warm up. Even 30 seconds is enough, like backing it out
of the driveway and parking it on the street.
3. let it sit several hours
4. restart
Change any of that and it won't smoke. The key thing seems to be that it will smoke hours
later if it is parked when it isn't fully warmed up. The usual tricks for making a car smoke because
of bad rings don't do anything. Once the initial few seconds of smoke at start up are over, one can cruise down
from 50mph then stomp the gas, and there is no smoke. Similarly, if after steps 1 and 2 the car is turned off,
and restarted 5 minutes later, there is no smoke.
The car has always smoked on starting if it has been a very cold night, near or below freezing, no matter what happened earlier. The sequence described above is new though.
Sometimes it burns oil. Sometimes it doesn't. There are no leaks and the coolant is clean.
Valve stem seals???
smokey start:
4. restart
Valve stem seals???
