heckaTIGHTis
- 2003.5 Mazdaspeed Protege
I fully intend to buy the Turbohoses hard pipe kit with my next paycheck. I'm sure that my stock plastic pipes could be leaking due to the fact I have 120k on the clock.
Do a fmic kit, it solves a lot of problems in one kit. The stock plastic pipes are crap, the interwarmer is what it is, the plastic pipes have leaks and break. Don't hesitate just do it.
hey new here(hi), i have the same problem on my stock msp the hesitation is around the beginning of the 3k rpm up to 4k, the hesitation lessens when i brought the boost back down from arnd 5 to maybe 1psi, i've heard its the fuel cut and the ecu reflash could help but i also heard the reflash is no good if you plan on increasing the boost....hella confusing...tempted to reflash it since i'm not getting the fmic any time soon...
This questions and problem have been floating around this forum for at least 6 years and I have yet to hear about a definitive solution, its all just hear say.
today was the mazda dyno day in PA. car ran terrible. had to take off the boost controler and go back to stock. very low numbers. but getting back to the jerking... i found possibly my poblem. the hotside intake tube from the turbo to smic. where the bypass valve connects is broken... I bumped it myself and it fell completely off so I guess a double or even tripple check for leaks is a good idea... right now its glued back on just to get me home from the dyno and gona order hard pipes right now anyone have any good sites for them or the best ones?
ok so that pipe didnt hole from the dyno day repair... so now I have a full leak in my hot pipe... and to be honest the car may run a little better... the only thing that has really changed is it will almost stall at idle but thats it no engine light no nothing... so im starting to think if a leak was my problem... I mean if the leak gets bigger I would think the problem would show itself more also.
but reguardless my front mount is on its way
