ive never tried the dual set up in question but i do have a valve that vent and recirculate my car runs like ass venting . just because it working for you with your set up . does not mean it will work for joe schmoe.505zoom said:How so? Getting better performance out of a better aftermarket BOV? RICE? Maybe you need to read the definition of rice thread again.
Thank you captain obvious... I think I finally understand the way that this setup works.(thought)
Have you tried the different setups? Do you have a WBo2? I have, and I have found that running the BOV/BPV setup makes the car go no richer than mid 12:1 while shifiting. That is fine, and with the vac signal coming from the BB line, it works even better than it did on the original setup.
take the pepsi challenge call 100 tuner shops and ask them if its better to vent or recirculate a MAF car . theyll all tell you you can IF . the only really accepted way to do this would be to move the maf near the TB or go to MAP
