Can't get my car aligned
Speedprotege3
2007 mazdaspeed6 2002 Mazda protege5
Put on sone lowering springs. Went to get an alignment and they said they could not put it in spec.
The car pulls right now pretty bad.
Some help please.
I'd go to a different shop. The only thing they should have an issue with is front camber and caster (if you don't have adjustable ball joints installed). As long as they can get front toe, and rear camber/toe, and the thrust angle correct you should be fine.
If your caster is off side to side, Mazda has a TSB that specifies new upper A-arms to correct the issue.
