Wiggles422
- MSP #654
Yeah, but it's still easy on the ground. It may take more time to get it on and off the lift than actually swapping out the motor mounts.
That VIOLENT shaking on starts from 0 MPH is what they (we) were talking about. It's violent and doesn't settle down. That's the only vibration that bothers me ... and you probably only get that vibration if you have the rear mount in I'd imagine.fkmp5 said:also, i was worried about installing it after reading others say they can't stand the extra vibration, but for me, it's such a slight difference, you can barely feel any vibration.. i wonder what they were talking about??
use some dyno mat in the rear hatch it should helpgirth said:That VIOLENT shaking on starts from 0 MPH is what they (we) were talking about. It's violent and doesn't settle down. That's the only vibration that bothers me ... and you probably only get that vibration if you have the rear mount in I'd imagine.
The exhaust does seem to sound a little different with the mounts but I'm sure it's just the engine making more "buzzing" "vibration" noise really. I like it except for at highway speeds...then it's too damn droning for me.
I use the same technique... took me a while to find it though. I hate those skinny little rails. They bend too easily, but they i guess they would work well if used with the car jack in the trunk.Black Majik MSP said:I don't know about you guys, but I can jack the front of the car up in under 30 seconds. I just used the front ball spot on the subframe to lift the front up. If you put jack stunds under the side, it's about a minute to jack the whole front up.
