Can't figure out CXRacing Intercooler on MSP
My friends and I installed the CXRacing Intercooler with cold air intake setup on my 2003 MSP. Car started up fine and with a few revs idling fine. Took it for a spin around the block and car sounded great but immediately stalled going into neutral. My friends and I can't figure out what to do, if anyone on this forum has this same kit and knows the work around please let me know! Any and all help is greatly appreciated!
For some further context, everything else on the vehicle is stock.
Any check engine codes pop up? Was there a factory intercooler on the car before making the swap?
Did you already have the cai before the new intercooler?
There's not much information on the original post to go with to compare what you had previous to the new setup.
I'm guessing you're still running the OEM MAF sensor with this new setup. Did you do a hard ecu reset before you set off on that short cruise with the new setup?
Any real time monitoring system or data logging tool to show you some parameters on air fuel, timing, and volumetric efficiency?
Sounds to me like too much air and not enough fuel when going to neutral but won't know until the above is answered for us to help. 👍
I appreciate the help guys!
So my friends and I solved the problem, whatever the MAF I had in (some cheap aftermarket MAF) was the cause of all the issues, Swapped it out with a Delphi MAF I had and its running fine again. It's idling at 1k and no issues when slowing down from a higher gear. Still a little awestruck with how the easiest fix is usually the answer sometimes.
Thank you Rufusjr21 and misnblu for replying and hopefully this helps someone down the road!
