A bypass valve is a valve that recirculated the pressure that is built from the turbo back into the intake of the engine because the pressure has to go somewhere. So the direct answer is no. You have not place for it nor do you have any need/use of it. I mean you COULD install one if you put a turbo on the car but if you are asking this question then I doubt you put a turbo kit on your car and probably just want to cool sound that the BPV makes.
