can someone please give me advise?
Speed3junkie
Mazda Mazdaspeed3 2nd gen
I have a 2010 mazdaspeed3 and my left back tire and my front right tire have negative camber really bad to the point of exposed wires on the insides of my tires after about 5,000 miles and you can tell by looking at it that they are leaning bad and I'm not too intelligent when it comes to suspension. I've replaced my rear trailing arm and whole hub assembly to try and fix the back and I don't know how to fix it, if I could get any advise it would be greatly appreciated!
Thanks so much.. Hope someone can assist me in my troublesome issue..
Sorry If I posted this in the wrong area I'm new here..
Yes it got hit and ran in a parking lot and my insurance is fixing it but can't seem to find the problem. They replace the whole trailing arm and hub assembly. And still doesn't help it and I'm just trying to find out more info so they can hurry up and get my car back to normal.
It is normal for front tires to wear on the inside down to the cord after about 10-15k miles if the tires are not rotated due to the factory alignment specs. The alignment is likely way off due to the accident or possibly from work the body shop did after the accident.
Find a Body shop that has a Shark measuring unit and they can tell if the unibody is out of wack, if a good alignment doesn't help!
Once the shop gives you good computer generated alignment data, if you find you have excessive negative rear camber, it cannot be adjusted because stock camber arms are not adjustable. You could install adjustable rear camber arms to fix that.
But if it's really far out, you need to make your insurance company get it right. That's why you pay the premiums.
