Camber adjustment kits for lowered P5s?
LazerBlueP5
2012 Cadillac CTS-V Coupe // 6spd
Are there camber adjustment kits available for our cars when we lower them. My old Tiburon was lowered via Intrax coils (1.75") and there was a visible camber change. In addition the inside walls of the tires wore sooner than the outer.
Also if they do exist, are their specifications for adjustment according to depth dropped? Thanks.
tirerack has eibach camber adjustment bolts for $24. an alignment shop would adjust as necessary. i've heard that for most cars, the stock adjustment can typically handle drops up to 2" and camber kits are needed for lower drops.
HondaKonzetsu said:
A company called FlyinMiata makes a camber adjustment plate kit for the P5. Its cost about $300 but its well made.
Goto www.fmprotege.com and check it out.
Flyin' Miata doesn't make the camber plates. Those that they sell are made by Ground Control.
The Ground Control camber plates will only really work with the Ground Control coil-over kit that they sell (the spring is considerably smaller in diameter). If you need just a minor adjustment beyond what the stock adjustment can handle, the camber bolts would be your best bet.
