ssinstaller said:
There are two switches on the clutch pedal. Just take the two wires plugged into the upper switch and connect them togeather(the wires should be 12~14 guage). The lower switch is for the cruise control, so don't mess with it.
2 things... one on topic, one off...
1. Wouldnt the most proper way of doing this clutch safety switch bypass be to install a relay in place to bypass the clutch only when the remote starter is being used? Thereby letting the clutch safety switch work as normal when starting the car with the key, and bypassing the clutch safety switch only when the car is started VIA the remote starter? This is how I hooked it up on my last car!
Starting the car in gear should NEVER be a problem if you buy a remote starter designed for a standard car; they will have provisions in place the make it next to impossible to start the car in gear.
i.e. When parking the car, the system has to be armed, (by pressing the start button on the remote while the car is still running), once this is done, the car would continue to run for about 5 seconds after the last door was closed (meaning you must have left the car in neutral). The system would be disabled if any door in the car was opened before you try to start VIA the remote.
This is just one of the methods I've seen that differentiates a remote car starter for a standard car from one made for an automatic car.
2. off topic, but why would there be a second switch on the clutch pedal related to cruise? I know the car needs to know if it is taken out of gear while cruising, but it seems to know already!
I HAVE taken my car out of gear while using cruise without pressing the gas or the brake, and cruise was almost instantaneously disabled. (RPM's jumped from about 2700 to 2800 and then cruise was automatically disabled)
Just curious if this is an extra safety measure?
