ssinstaller
- 2006 MazdaSpeed 6
bluntman said:Can someone explain this diagram, and how to assemble it, in layman's terms?
Thanks!
What is a DRL?ssinstaller said:You can make some simple modifications to the relays that come with your HID setup to eliminate the flicker caused by the DRL setup in the mazda 3.--This deos not remove your DRL it just remove the flicker that the pulsing causes.
Gotcha! ThanksDexter said:DRL = Daytime Running Lights. I think its government mandated in Canada.
cebo0650 said:Can you please confirm the specs of the capacitor? I'm not really sure what is ment by 10K uf. I have never seen such capacitors.
mobomelter said:*smacks head* i should have remembered that from chemistry and electronics.
cebo0650 said:I just bought all the components for this today, and I hope to have time on Monday to start the build. Has anybody actually tried this, and did it work?
