Did you make sure your spark plug gaps where correct?
if copper for sure check this, any other type you do not gap, as that can flake or scar the platinum or iridium plating
The NGK ones should come perfect... you can eye ball them to make sure they haven't been damaged, but they shouldn't need to be gapped.
nope...not at all A L W A Y S check gapping 28 -32
That's turbo gap, n/a will be .044"
How many miles?
Replace your coil packs!
They're 25.99 a piece and probably need to be changed anyways. Mine were shot at 125k but the 01 protege i had before were shot at 90k. they're a common problem and will cause a bucking/misfire. sometimes it wont throw a code and sometimes it will.
, a good way is get a code scanner with live data and rev it to 3k rpm while watching data and see what engine load, throttle position ect do. how bad is the bucking? is it really hard almost killing engine? or just barely noticeable? or in between? it could be a cam or crankshaft position sensor as well, though those usually set codes and/or cause hard or no start conditions or engine dying while driving but a weak or failing one can cause your issues.
1st time posting
I tried searching but found nothing that actually fixed the problem. I mostly found suggestions but most seem way wrong.
Its my wifes protege 5
Only when the car is warm we will get a bucking/ jerking at 3000 rpms when we are under acceleration. Once we get over 3000 rpms there are no problems. This happens in all gears right at 3000 rpms and when its warm. It feels like it just looses power for a split second and it could happen 1-3 times as we pull through and past 3000rpms
It started a month or so ago and seems to become a little more common.
Heres what I've done since
Changed plugs- didn't help
Replaced muffler- seems it happens more
Tried to find vaccuum leaks and I found none
Check codes and none showed up
Right now I'm having battery issues so I pulled the battery and I guess it will reset the computer.
Other people with the problem are always told to change the coil packs and that never seems to fix it
Any ideas?????
