SpeeddemonRobb
- 2003 Mazda Pro5
OK ~
So the dealer told me that I have a wheel bearing going bad as well as the axel carrier bearing. $850 for them to do it, hell to the no. So I order my parts and pop her up onto the jack stands and start removing parts to get to the goods.
Drivers side did not give me any problems at all. That being said, the passenger side is a different story.
First off, the 32mm nut. Got the socket, and attached it to a 2 foot breaker bar. Wouldnt budge even with me stanging on the bar. So I got the jack handle to add another 4 feet to the bar... Snapped the breaker bar @ the connection to the socket. Tried again, with another breaker bar, same result. Went to Home Depot and "rented" (bought and returned) a 25 gallon 200PSI air compressor ~ that did the trick with the nut!
Onto pulling the hub / spindle off the axel... Borrowed a gear puller from Autozone, and it worked just fine on the drivers side, but again, with the passenger side! I now own a broken gear puller. I went to Checker auto parts and borrowed one from them too, and although I didn't break the tool, the end that snugs up against the axel shaft now has a deep impression where the tool was resting against it.
I have heated it, and used PB Blaster, liquid wrench and all that as well, and the axel splines refuse to let go of the hub.
Frustrated?!?!? YOU BET!! That $850 is starting to look like it would have been money well spent, but I cant take the parts back, and I would still have to put all this s*** back together. I dont want to give up.
Have any suggestions?!?
Help me Obi-Wan Kenobi... You're my only hope!
Robb
2003 Pro5
Robb
2003 Pro5
