New here to the site. I have 08 Mazda 3 Hatchback with the 2.3 and a 5 speed.
I replaced the front Rotors and Pads yesterday. The old rotors were warped. Anyways replaced them with Napa parts. They seemed a little soft but everything else seemed fine. Until later in the evening, periodically the brakes would make groaning sound and NOT while applying the brakes. They also seemed to make the noise while turning left.
I did NOT use any kind of lube on the pads and I cleaned the new rotors off by spraying them with brake cleaner. Could they just be working themselve in? I have done may brake jobs in the past on much older vehicles and have never run in to this issue.
Also, the new rotors appear to be scatched on the bottom half.
Any all suggestions are appreciated. Thank you.
