I recently changed the rotors and pads all the way around on my 02' Protege 5. I did the work myself and for the most part i was pretty happy (had one busted rear caliper ). So its been about 1000 miles since my repair and i notice that one of the front rotors isnt wearing like the rest. Seems like the pads arent gripping the entire surface of the rotor? Insted of the whole pad contacting and wearing the rotor only 2/3 of it is? Could someone go outside and look at your FRONT pads and tell me if the "low brake pad" warning sensor (clip) is on the outside or inside pad? Out of four pads only two had warning clips and i stuck them facing out. Just wondering as it looks like that clip is sitting against the caliper, so could be the problem. Thanks for looking folks (if you can).
