Brake handle buzz
drosene
My 2008 Mazda 3 has an annoying buzz coming from the button on the end of the hand brake handle. Simply touching the chrome button when it is buzzing is enough to stop whatever vibration is causing the noise. The most obvious solution is to tighten the cable that would normally connect the brake handle to the rear parking brakes but I am unable even see the cable much less any adjustment points.
Any ideas?
Welcome to the forum.
Your post is in the correct place, it's probably an uncommon problem. I don't think cable adjustment is the problem. It could be the spring under the button on the handbrake handle. If the noise stops when you touch either the handle button or the handle it may be in the pivot area of the handle. There has to be some play in the mechanism for it to function properly. It's simple ratchet and pawl system with a spring for control. I doubt if can be easily fixed. A replacement lever may corrrect the problem. I have a 2008 Mazda 3 and haven't noted the problem in may car.
Sorry I cannot provide a simple answer.
Clifton
i have the same problem, 08 2.3L S Sport sedan. ive gotten used to it. i have a poly rear motor mount and torque damper so now more things that just that rattle. lol but notibly, it made the rattle before any of that, it doesnt twist, i think its just cheap....o well
