HondaEat-R
You either have a seized piston, seized slide, or maybe both. Take off the rim, remove bracket, polish/sand slide, re-grease with high temp grease/never seize. If piston is stuck, you prob have a torn boot around the piston. Spray WD40 in to the torn boot & have someone in the car push the brake pedal so the piston comes out, then work the piston back in with a C-clamp. Do this until you feel the pistom coming out easier. When you think you're done, give it another shot of WD40, then pack the hole in the boot with heavy high temp grease. OR Buy a new caliper, haha. GL
