BOV flange
boostedmazda
Mazdaspeed
i dont know if there is another thread on here about it, but is there any kind of flange for a greddy type s that will connect it to the stock IC piping:confused: ? if there is another thread post it please, thanks.
no flange will fit the stock piping. its all plastic. you try welding something metal to plastic you're going to run into more bad issues than you can imagine than you started off with originally. but best of luck to ya
www.3sxperformance.com
they have and adapter that will allow you to plumb it in to the stock piping, but i can tell you right now that you will not the souind you want, it will still sound like the stock bpv with the turkey. problem is, its too far away from the TB and the stock outlet on the intercooler charge pipe is far to small to properly vent all the pressure, wich is why you want get the sound. ive tried, doesnt work. so you'll have to go for hard pipes if you want it.
i saw it a while ago on here but someone had a bov flange w/ stock ic piping. of course, it's not worth the trouble- get hard pipes==no swelling of the pipes, and nice bov sound!
