Bottom Grille
123zoom
okay, i got the top grille off, and now i'm on the bottom........i unplugged the 4 clip things in each corner but there are 3 vertical bars running behind the grille and i dont know if thats what keeping the grille locked in still......can nebody help me in gettin off the bottom grille
yeah that is it .. on the top and bottom of the grill there are little clips that wrap around those bars and lock it in .. so its easiest to jack her up and lay underneath the nose of it and squeeze your arms in it that way and pry them apart slightly and push the gril out
the thing is, when i get underneath the car, i can't see those vertical bar things so i don't know what to unclip, is it at the top of teh vertical bar or at teh bottom that i need to unclip?
many people tell me to just unclip the 4 clips in each corner and then just pull the grille, but wont' it break!?!?!??!?!?!?!? it looks pretty damn secured with those vertical bar things
I finally got it all off!!!!!!!!!!!!!!!!!! the bottom one i just unclipped the 4 corners and then alittle tug on each vertical bar did the job, I had to pull it out from teh top, then teh bottom
