boost cut
how many people here have it? what mods do you have?
also anyone running a mbc/ebc to actually lower boost a bit in order to avoid fuel cut?
lots of people run boost controllers of some sort.
what you really need is a map clamp or ATP boost cut defender module. Both work the same way, by limiting the amount of pressure that the MAP sensor sees.
I hope this helps some.
my thing is im not looking to get rid of the boost cut. i just dont want to it happen all the time. i would rather keep the safe guards
