doughboy52
Contributor
- 2013 CX-5 Touring FWD Sky Blue
Anyone have some recommendations on bolts to use on the license plates that won't rust and corrode?
While stainless steel is corrosion resistant it will eventually rust. Especially if you live anywhere that puts down road salt.
Every type of stainless steel is susceptible to corrosion and rusting. It's not a matter of if its a matter of when. Even Marine grade SS which is usually SAE-316 will rust under the right conditions. http://en.wikipedia.org/wiki/Marine_grade_stainless If one was going to shell out the money for Marine Grade (316) stainless they might as well get titanium or aluminum which won't rust, ever.There are grades of SS that don't rust but they are very expensive and you probably won't find them at your local hardware store. A good marine store will carry them but be prepared to bend over as you pull your wallet out.
For holding a license plate on the nylon ones are excellent.
Lots of great info, and I'm glad a few of you mentioned the M6 x 25mm/1". That's all of the info I was looking for in addition to the recommendations on types of screws. Anyone know if the front ones are different since they screw directly into the bumper cover? I know I could back them out to check, but it's much easier if someone knows offhand![]()
Even titanium fasteners (and especially aluminum fasteners) are susceptible to corrosion. Titanium, aluminum and SS alloys all get their corrosion resistance from the surface formation of an oxide film. Depending upon the environment, this may not be enough to prevent further corrosion.
As an ex-Alaskan commercial fisherman, I can tell you that #316 stainless steel has more than adequate corrosion resistance to use as a license plate fastener. It is even used for implants within the human body. Aluminum alloys, not so good for license fastening unless it's anodized and even then you might have trouble. Titanium alloys have varying degrees of corrosion resistance, typically more resistant than SS and aluminum alloys but at a cost 2-3 times that of #316 SS. A good choice if you don't mind the cost.
