I did some searches and was unable to find the answer so here you go. I installed a bluetooth kit the other day in my 2007 non-bose 3 and followed the pin-out below. I used pin L for the telephone mute but I can't get the mute to work with the bluetooth kit or when I ground the L pin. My understanding was if the L pin is grounded it would mute the radio but this doesn't seem to be working. So essentially the bluetooth unit rings or I place an outgoing call and the radio doesn't mute. Again its an 07 so I have the clarion radio. Do I need to use a relay? Just trying to figureo ut what I'm missing. Any thoughts or help would be appreciated.
Thanks in advance.
This is back of HU pinout:
|..X V U S | ##### | F D C A |
|..W...T.......P N L J H..........B. |
|.............R Q O M K I G E....... |
A Left front door speaker (+)
B B+ (Power back up)
C Left front door speaker (-)
D Right front door speaker (+)
E Illumination (+)
F Right front door speaker (-)
G Illumination (-)
H - pwr ant
I - speed pulse
J - amp remote
K - nav: parking brake
L - telephone mute
M UART 1
N Audio control switch 1
O CAN (+)
P Audio control switch 2
Q CAN (-)
R ACC
S Left rear door speaker (+)
T Signal ground
U Left rear door speaker (-)
V Right rear door speaker (+)
W Power ground
X Right rear door speaker (-)
Thanks in advance.
E Illumination (+)
G Illumination (-)
H - pwr ant
I - speed pulse
J - amp remote
L - telephone mute
M UART 1
O CAN (+)
Q CAN (-)
R ACC
T Signal ground
W Power ground
