This has happened to me twice now. Driving down the road at crusing speed (50 mph once 75 mph once) engine loses power and I get a blinking check engine light. The engine comes back seconds later and by the time I pull over to the side of the road the CEL is now just solid. Car runs fine. The idle dips a little low sometimes and causes a bit of a shudder but other than that runs fine. I guess my question is could this be the EGR valve causing problems? The car is an '02 with 65k and I'm not sure what the previous owner did about maintainece. Ive only had it since October. I don't think its the VTSC screw thing because the engine just loses power, no clanging or 'chewing' sounds. If I recall correctly it happened both times in cold weather, lower to mid teens. I'm running some seafoam through the gas so if there is any moisture in there I can hopefully get rid of it. I'm planning on pulling the plugs and replacing those when it warms up a bit. Anyway, any thoughts or suggestions?
Thanks
Thanks
