Blank Switch Plate
Woogi
I have a 2004 Mazda 3, and I just ordered an in-line RF Modulator (iSimple IS77). This unit comes with a mountable on/off switch. I was planning on mounting the switch on the left side of the wheel where the dimmer wheel is, but (i have not received the iSimple yet) but I belive the surface will need to be flat, rather than bubbled out.
I was wonder if anyone know of a 'flat' replacement I could use or a better/different spot to mount it.
link to photo:
XXX.newegg.com/Product/ImageGallery.aspx?CurImage=82-781-009-S05&ISList=82-781-009-S01,82-781-009-S02,82-781-009-S03,82-781-009-S04,82-781-009-S05&S7ImageFlag=1&Item=N82E16882781009&Depa=0&WaterMark=1&Description=Isimple%20IS77%20FM%20Modulator%20iPod%20Cable
EDIT:replace XXX with WWW in address for it to work.
link to photo:
Linky no worky. :(
You might try looking through a junkyard. Some other Mazda models had flatter blank plates for the switch areas..... I want to say 626, 929, protege, etc. Everyone I've seen so far has been swappable with the 3's blank spots.
