Black hatchbacks Post em
you should have put that backwards it's much more effective to pull heat out if that was your plan. All the subi guys used to get the reverse hood scoops, I sure did when I used to run my 2.5RS.
OMGFLUSH Set up
Evo X wheels :D
To do this you need to figure out the right lip at the front of the "reverse scoop" in order to get the right amount of negative pressure. There's a chance that it won't do anything and potentially upset the air flow in a bad way and trap more heat. Then again, I'm not an engineer, so it's purely speculation.
Evo X wheels :D[/QUOTE]
Evo X wheels, meaning they were once installed on an Evo X? They look like G-Forces to me...
Yes it is, and I think it looks sexy on a ms3, I have contemplated doing this before, this REALLY makes me wanna do it.
Wastegate13..... I missed you at EECMM this year whats up with you not coming? This pic from my dragon run this year should make you happy LOL
I'm going to Costa Rica in August for 15 days and I wasn't sure if I was going to have enough leave for both trips. I tend to rotate my hobbies and I haven't cared about the car for a while now. I might get back into it soon.
um its an oem mazda 3 wing? You should be able to find them anywhere. It does look amazing, however, on the speed 3 body IMO.
