yellerandahalf
- '03.5 MSP(Yellow!)
Ok, I'm running out of brakes on track, and have started looking into big brake options for the protege. So far, what I've come up with are a few interesting options:
RR racing has several options for us, including two kit: one that moves the caliper outwards, and utilized bigger (12"x1") rotors (still fits in stock 16" rims), and one that's a "4-pot racing caliper kit" that i don't think fits in stock rims, and has 13" rotors.
For reference, the stock MSP rotors are 10.75"x .984".
my concern about the 12" kit is, if you move the calipers outwards, the pads will not be contacting as much of the rotor surface as before. This might negate the point of getting larger rotors.
Another option is the corksport kit. it uses 12.75" rotors, new wilwood calipers, and will only fit in 17" wheels. It's 1200 bucks.
E-racer has a kit available, it uses 11.7" rotors, but they're only .81" wide. not even as wide as the stock MSP rotors. Probably not a good idea, at least for us MSP guys. It does use wilwood 4-pot calipers though. They offer a full kit or a "DIY" kit. the full kit is 750, whereas the DIY kit is 130. Not a bad option, really. Not as big as I'd like personally.
Thoughts on the matter? other factors that should be taken into account?
-Mateo
-Mateo
