Better PCV Valve Solution For Low Boost Applications
just some new before and after pics of pcv and new vac lines
here is my set up. the oil catch can definately accumulates oil!
I should stick a filter in to check on mine. I've been running the millenia PCV for a couple weeks now (ever since I went turbo).
Tzar, is that with the millenia pcv, and are you turboed?
yes it is a milenia pcv...or was. i broke it today replacing the seal, so now i just have a pepboys bought pcv in. at the time i ordered the milenia pcv i wasnt aware this upgrade was meant for applications with turbo. thought i'd see how it turned out on a N/A setup.
I've read through the majority of the posts and I realize this mod is most beneficial for turboed engines but would this mod do anything whatsoever for an N/A engine? I saw this same question asked a couple of times but no answer was ever given.
No.
Maxx Mazda said:
Didn't I sell you somethign a long ass time ago? Your name is charles, right? What was it?
That would be me! Honestly I can't remember if I bought anything from you. I've bought lots of stuff from this forum and it gets kinda mixed up in the ol' memory banks, ya know? Anyway, thanks for the heads up about the PCV valve!
A grille and an emblem according to my records...
Aha! That's what it was. It is currently residing comfortably on the car with the top trim body match painted and the emblem was modded a little bit. Man that was a while back, at least it seems that way.
