absolutelyBlkZoomZoom said:If you have a stock msp. Then stock plugs are the best.
ChopstickHero said:then that guide should be UPDATED!
What should they be gapped at?
worse combustion.RYuReady said:I'm new to this car stuff and was looking into spark plugs also. I was wondering if it is a big deal to replace our extended reach plugs with non-extended reach plugs. Are there advantages and disadvantages? I'm assuming it would probably be safest to replace the extended reach plugs with another extended reach plug, but would putting a regular plug work with no problems or maybe even better combustion?
Dr.Sound said:worse combustion.
my car idled rough......it also seemed like it didnt have as much power as with extended reach plugs.
i now have NGK ZFR7F-11 and they are great.
when i took out my non-extended reach plugs, they were all black. at that point they had about 5000 miles on them.
when i last checked the extended reach plugs that i have now (after 8000 miles) there were no carbon deposits on them at all.
Dr.Sound said:i now have NGK ZFR7F-11 and they are great.
FlyinMSP said:Stock, get the ZFr6F-11 (6, not 7!) or IK20 if you want iridium from Denso or ZFR6FIX-11 for NGKs iridiums (I used them for a year and they are very good)
Note: they are all pre-gapped at 0.044 which is fine for stock (bigger spark)
