yashooa said:Pardon me, yes my endtanks were TOO ******* LONG as well thanks for reminding me
The pipes were too long and the endtanks came in way too far towards the engine.
As far as fuel goes I was just running the stock injectors and yes they would lean out a bit 13:1 and if I choose to not modify the MAF voltage via the MPI then it would hit cut. But you would be suprised how well these little guys held up under warmer weather.
I will be adding the extra two injectors to the mix because really that is the only non-half assed (yes I too was running half-assed) way to run the MPI and this in fact was the designer's intent.
You will get a nice increase in fuel with the two new injectors running in the IC pipe just ahead of the throttle body and it cools the charge some.
Tibbytomazda said:ill stay below 10psi but i want a fmic so whats the best
MSPRM said:Will the Hiboost kit support 300 whp nicely?
mike2225 said:The best one for what your looking for, would probably be the bell engineering FMIC.Protege Garage has them on there website
sandspeed said:I've only had experience using my begi fmic, but it's a great kit. There were a couple quirks here and there but it worked out in the end.
Lodivigo said:It's been discontinued, I've had one on order since late April and was informed the other day about this. They threw out the tooling for the pipes and so they are no longer selling the kit. I had my heart set on it so I'm trying to see if I can get the kit anyways but without pipes, I'll make those myself if I have to. Hopefully they can still get me a kit, waiting on a response from BEGi.
quick question. i just ordered my perrin, one of the last ones and yes i paid a s*** ton for it and probably shouldnt have. but i was wondering, did they end up working out the problems with the end tanks and pipes?MSP608 said:lol sorry for getting technical, just what perrin told me. thats crazy that stock injectors could handle 20 psi. i have one extra injector, 750cc plus the stockers.
xgeoffx801 said:quick question. i just ordered my perrin, one of the last ones and yes i paid a s*** ton for it and probably shouldnt have. but i was wondering, did they end up working out the problems with the end tanks and pipes?
Awesome man thanks. Now my next question. Is it something I can put in myself, or should I just pay to have it done?MSP608 said:the problem i experienced was with a certain batch. you should be good to go.
orng1 said:Really depends how comfortable you are with doing stuff yourself. If you've never done something like this before invite a friend with a car to help, you'll thank me later when you need a ride to get a special tool or extra clamp in the middle of the job.
