by going the intake first, you'll
1. discover our cars produce a massive turkey noise, which may lead you to...
2. want a bov, then you'll discover the most bov will either not get rid of the turkey or will make your car stall, so then you'll probably go some rout of dual bpv-bov which will require you to...
3. get hard pipes, which will make you consider to jus...
4. buying an entire front mount intercooler setup, at which point you have already spent hundreds more than you expected, also sooner than you expected and still have only minimal gains.
as far as boost controller, jus stay away from that until you have the testpipe/midpipe, fmic, AFC, and some colder plugs.
do it the right way, exhaust-fmic-afc-boost controller. you'll be happy w/ your results.
