BC question
hawaii3
Mazda, Mazdaspeed 3
ok so im planning on getting 18x8 45 offset rims wrapped with 225/40 kumho spt's. also at the same time lowering it on BC's as low as it can go. (not taking any rings off). will i rub? and if i do is it easy to adjust the height of the BC's front and rear? also planning on ordering rear camber arms to adjust it to atleast stock settings.
I'm on BC's all the way down with 225/40's on RX-8 wheels and I don't rub. I don't have camber links so I'm running -2.4 in the rears. Since you'll be 5mm out more, you might rub. But just go with the set-up you're going with and if you need to roll, then just roll the rear fenders.
thanks guys. and thanks strick- for the info for the vents. it was super easy, i left the insulation on and just put double sided tape to hold it up. ill post up some pics when i get them. it probably wont be until january as im going to japan in the winter and waiting for my stockers to bald.
