battery terminal wire is corroded
hello, my battery terminal wire has corroded and im wondering if anyone knows where the negative terminal wire grounds to? Ive noticed that there are 2 wires that go to the negative terminal. one wire runs under the battery mount and im unsure where it goes to. any help would be appreciated!!
I found this.
Edit: Oops, that's showing the positive.
I took a picture of my parts car and it goes into a loom.
You could try one of these...
It looks like you've got a bit of length to work with.
Maybe cut 1/2" off the wire to get to some cleaner wire.
One wire goes to the strut tower and the other wire grounds to the top of the transmission. You can see it if you take out the battery tray in my car.
You should have plenty of play in that wire to strip it and put a new terminal on.
I know, ..
I'm just being lazy...
I've got CAA now, so they can tow me home to replace it.
I've got 200 KM of towing.
