Bad quality brakets and bushing sway bar progress
Waltz
HI everybody,
I have a big problem. My right bracket have broken. It was installed 2 months ago when I dropped my car.
Anti-sway bar progress 22mm (painted in red)
How can this bracket have broken like that ?!? :mad: :mad:
Here the pictures.
Broken right braket:
Another view:
Here is the left bracket with the bushing. Its easy to see that the bushing is now broken in the middle.
So now ... where can I buy new brackets with bushings at good price and it can be ship to canada
Thank you
Wow, that sucks. Progress should have provided beefier brackets, since their bar is about 3 times stiffer than stock. There's a lot of force on those brackets!
carbonkid said:
PM EVOLV, he may be able to help you...
That one pic (unbroken side) shows a helluvalotta bar AND bushing stuffed into a bracket that seems barely as big as the naked bar. Wunderin' if the MSP X-member would work with the Progress bar. The Horseshoe brackets are hella bigger, the bushings, I dunno, maybe something would work. The subframe is only $66 from MMS
