1
151614
2016 CX5 Akera Diesel AWD auto. Location Australia.
Car is 6 months old. 6500kms.
When the engine is cold, and I first drive off, the gear change from 3rd to 4th flares most times.
By flares I mean it's like it partially misses the gear change and revs up anywhere between 500-1000rpm and then changes gear. Only does it the first time it gets to that 3-4 gear change, next time it gets to that change its fine. Only does it on the 3rd to 4th gear change. And once the car has warmed up a touch, no problems.
If I stop the car for a couple of hours and then come back, start and drive off, and it will often do the same thing again. Just the once!
It's been doing this since new. Very annoying, it simply shouldn't happen.
Mentioned it twice to my dealer- first time at the 1month/1000km check, when they say they've checked software and diagnostics and no fault codes showing up. That time they said they did a sw update, but frankly, it made no difference.
Second time was about 2 weeks ago when it was in for warranty replacement of the EPB control unit, they said they checked and couldn't find anything.
I had a 2013 CX5 GT diesel before this car and had no such issues.
Any thoughts??
Any thoughts??
