att d3ny
unr8ted
Ok guy well i meet you all last week. well all has been well for a tank of gas. got gas and started to run like crap back firing mis fire in cylinder 1. well it killed a spark plug so i checked that. the coils are all firing also. i checked the o2 also and the maf. after i did that all i got a new code p2188 rich at idle code. any feed back what will cause that egr valve makes funny noise would that cause it ????? well i did a idle log plz read and get back to me plz thanks guys
you have a vacuum leak without a doubt. idle pressure should be roughly -10.5psi, not 9.
your actual afr is very rich, which is why your trims are off. they should be 14.7
possible causes:
dead MAF sensor
dead o2 sensor
big leak somewhere between the turbo and manifold (check ur bpv)
i have the manual at home, when i get home from work ill take a look
well i checked the bov it was to loose on the setting that fine but what will make it eat a spark plug. any ideas maybe a intermite stuck injector ?
